AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISOMETRIC FLIP ANGLE ERROR
4 REPLIES 4
csl24R6N
503 Views, 4 Replies
Angle error when using a flIP with each flange
4 REPLIES 4
h_eger
in reply to: csl24R6N
Dear @csl24R6N ,
wWhich component is this graphic about?
an arrangement with these connection points should be represented in Isometric as a 180 elbow return.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
csl24R6N
I want to make that gauge. Please make sure it is correct.   the symbol appears in only one direction
h_eger
Dear @csl24R6N ,
as already written a 180-U-Elbow should be used.
Hartmut Eger
Senior Engineer
XING | LinkedIn
MateusMaciel
@csl24R6N As quoted by @h_eger my suggestion is to insert the SKEY = EUFL
Regarding the end, there is no need to worry, as p plant 3d will automatically insert the one configured for the respective port in the spec editor
mateustilapa@gmail.com
