Isometric error according pipe direction
Dear all
We are developping parts to use for jacketed pipes. It consists of a transition plate between the inner pipe and the outer pipe. We can also add a drain on the plate if necessary.
You can see a 3D view on the attached picture (3Dview.jpg)
The part is defined with 4 ports:
1. Inner pipe In
2. Inner pipe Out
3. Outer pipe
4. Drain
See Iso.jpg for the symbol associated.
When I use it on vertical pipe I have my isometrics without any problem. It’s not perfect but it should be enough for us. (see iso.jpg, left is inner pipe and right is outer pipe)
But when I use it on horizontal pipe I don’t have any isometric (see log file below) and I don't really understand what says the log file.
Can someone help us ?
Why it works in one direction and not in others ?
Thanks in advance.
François Salmin
