AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
isometric drawing
6 REPLIES 6
MKK20
540 Views, 6 Replies
isometric drawing
Is there anyway to generate "iso massage" with some symbol in isometric drawing...by using SKEY etc.
@dgorsman @jabowabo @Tomislav.Golubovic @h_eger @DGRL
Labels (2)
6 REPLIES 6
h_eger
in reply to: MKK20
Dear @MKK20 ,
could you please give an example or define your requirement a little more precisely. Since I don't quite understand where the journey should go!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
MKK20
in reply to: h_eger
i want to use iso massage feature with dimension which is working perfect but i want some kind of symbol also there........here's are some photos
@h_eger
George.Endrulat
in reply to: MKK20
We do something similar, we use a custom support and have the type as MISC-COMPONENT and the skey as the block we need.  It works, throws a dimension on, and places the item in the bom as a misc-component.  You can make it look however you want in the 3d model.  I think this is what you're after.
George
If my post offers a solution, please click "Accept as Solution"
MKK20
in reply to: George.Endrulat
YES THIS IS THE ONE WAY ..BUT I AM JUST FINDING IF WE CAN DO SAME THING USING ISO MASSAGE INSTEAD OF CUSTOM SUPPORT
yes this is the one way...but i am just finding if we can do same thung using iso massage instead of custom support as it will not work properly for inclined pipe
h_eger
in reply to: MKK20
Dear @MKK20 ,
as @George.Endrulat  describes this, it is the only way I know to get graphic symbols with information on the ISO.
Unfortunately, the ISO notification function cannot be expanded and is therefore not an option for your project.
Hartmut Eger
Senior Engineer
XING | LinkedIn
jabowabo
in reply to: MKK20
The isoconfig.xml file can be modified to achieve your goal. You can insert specific blocks by triggering on the text contents of your iso message. Example for a Tie Point symbol:
Annotation Scheme:
<ComponentScheme Name="TieInPointTag" AnnotationStyle="TieInPointAnnoStyle" Format="{0}" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="TieInLeaderStyle" Filter="MessageTieInPoint" Fields="TEXT" Placement="Center" />
Annotation Style:
<AnnotationStyle Name="TieInPointAnnoStyle" TextStyle="AdskIsoAnnotation" BlockName="AnnoTieInPoint" ResizeBlock="None" />
 Filter:
<Filter Name="MessageTieInPoint" Value="Type='MESSAGE' AND (TEXT LIKE 'TP*')" />
Dimension (if required):
<AnchorPoint Name="TieInPointDimension" Enabled="true" Filter="MessageTieInPoint" IsLocatingPoint="true">
