Message 1 of 10
When an isometric is generated with 2 or more supports on a straight length of pipe the isometric dimensions the first & last support from the wrong end which makes those dimensions overlap other dimensions.
This happens even if I create a new model so not a corrupted file. I have tried playing around with the settings but nothing seems to fix this issue.
This also happens in the standard plant3d isometric spec, such as 'Final A3' which I have not moddified.
