Isometric Dimensions Overlaping
peter_harrison
Message 1 of 10
peter_harrison
When an isometric is generated with 2 or more supports on a straight length of pipe the isometric dimensions the first & last support from the wrong end which makes those dimensions overlap other dimensions.
This happens even if I create a new model so not a corrupted file. I have tried playing around with the settings but nothing seems to fix this issue.
This also happens in the standard plant3d isometric spec, such as 'Final A3' which I have not moddified.
Replies (9)
Message 2 of 10
AndyDavisArkance
It's a defect with String Dimensions in the iso generator in 2022.
Andy
Andy Davis
Industry Specialist
ARKANCE
Message 3 of 10
Ray_K
Yes. I noticed that too in 2022.
Message 4 of 10
jarrod.mudford
Works fine for me.
Jarrod Mudford
JAYEM Solutions
jarrod,[email protected]
www.jayemsolutions.com
Message 5 of 10
JUANCARLOSBLASCO4129
Any update on this?
@jarrod.mudford , can you upload your isoconfig?
Message 6 of 10
m.bevers
Is it just me or does this bug still exist in Plant 3D 2023?
My project setup iso dimension setting for supports:
Generated isometric looks like this:
Initial dimension on most right suspension support, is placed really weird/incorrect, as you can see below:
We have about 300 lines to generate iso's from. Surely I hope we don't have to correct each isometric manually! 😥
Did anyone manage to find a proper solution for this?
Any of the moderators @joaquim.moral@Vicky.Wu,  @Tiana_Y@lim.wendy that can help maybe? (Sorry for tagging, but I really need help with this)
Message 7 of 10
In theory, it has been solved in update 2023.0.1, according to patchnotes
I haven't tested yet
Message 8 of 10
m.bevers
I'm afraid it's not, as apparently I'm already using that version:
Message 9 of 10
Hi
I've tested it and worked flawless :
My string config is the same as yours
Before the update, it doesn't work.
¿Have you tried in a new project? Maybe the isoconfig is corrupted.
I hope you solve it, i've been  running plant 2021 until now becouse same reason
Regards
Message 10 of 10
m.bevers
Ah! It works properly now!
You guys were right, I had to update Plant 3D 2023.
In my earlier post with the version screenshot, I just clicked the question mark in Plant 3D and selected "About Autodesk AutoCAD Plant 3D". But apparently that's not showing the Plant 3D version (probably only the AutoCAD version?)
Anyways, I had our IT perform the latest Plant 3D update, and now my isometric looks like this:
