Isometric dimension Settings
Ahmed1081975
Ahmed1081975
Hi all,
I'm trying to setup dimension settings with the correct way, but the output isometric provided like as shown in the screen snap
Please Advice
Ahmed Helal
JUANCARLOSBLASCO4129
Hi
Can you check if your options in Dimensions and Themes are like this?
See an example :
If not, can you provide some screenshot of you Dimensions and Theme config?
Regards
Ahmed1081975
Many Thanks for your reply
it's became better, but still some small issue regarding overall dimension & Reducer & small bore pipe
see below the screen snap
Ahmed Helal
I'm sorry
I've tried to replicate your iso with the default settings, that are equal than yours and mine uploaded earlier.
See result with quick iso:
It works as intended.
You can try to create a new deault project and import drawings.
Ahmed1081975
No issues i'm satisfied with your solution
Thanks Again
Ahmed Helal
