AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric dimension- oblique text
4 REPLIES 4
1299 Views, 4 Replies
Hello guys,
Can anyone tell me on how to turn off the the oblique text on the dimension of isometric drawings?
4 REPLIES 4
jhamilton
I am asking the same question.  We need to turn off the oblique text
Is this really not possible in project setup or isoconfig? Using Plant 3D 2019.2.
Any input would be helpful. Thanks.
DVaquand
Hello
Sorry for my English, which I don't speak and whose post has been translated with DeepL Translator
You can deactivate the italics of the dimensions by modifying the ISO.DWT file of your iso output style
Open the ISO.DWT file
Open the text style and create two new text styles.
In my French version they are called "AdskIsoMetric-30" and "AdskIsoMetric30".
In English version I think they are called "AdskIso-30" and "AdskIso30".
Create a style AdskIso-30 and give it an oblique angle of 0
Create a style AdskIso30 and give it a slant angle of 0
Quit the ISO.DWT file saving the changes and launch a new iso with this style.
If you want to have always horizontal dimensions in this case it is necessary to modify the styles of
dimension "AdskIso" and or "AdskIsoMetric" and define the writing of the horizontal dimension.
Personally I prefer the dimensions as they are by default, i.e. aligned to the dimension line and with an oriented writing.
== French ==
Bonjour
Vous pouvez désactiver l'italique des cotes en modifiant le fichier ISO.DWT du style de votre sortie iso.
Ouvrez le fichier ISO.DWT
Ouvrez le style de texte et créez deux nouveau style de texte.
Dans ma versiobn française ils se nomment AdskIsoMetric-30 et AdskIsoMetric30.
En version anglaise je pense qu'ils se nomment AdskIso-30 et AdskIso30
Créez un style AdskIso-30 et donnez lui un angle oblique de 0
Créez un style AdskIso30 et donnez lui un angle oblique de 0
Quittez le fichier ISO.DWT en sauvegardant les modifications et lancez un nouvel iso avec ce style.
Si vous désirez avoir toujours des cotes horizontales dans ce cas il faut modifier les styles de cote
AdskIso et ou AdskIsoMetric et définr l'écriture de la cote horizontale.
Personnelement je préfère les cotes telles qu'elles sont par défaut, c'est-à-dire alignées à la ligne de cote et une écriture orientée.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
in reply to: DVaquand
This makes perfect sense! Thank you. Even if you can’t just turn it off, this is a great workaround.
Technology Administrators
