Does anyone know why my isometric break points are being ignored when generating the isometric? I have my line number set to the correct number, my layer is set to "0". The "Ignore break points from model" is not checked in either the project setup or advanced iso creation options.
because they are not on the right line or are not connected to the line
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
can you provide me with a PCF file?
Change the PCF file extension to TXT otherwise it will not work with the upload
Hartmut Eger
Senior Engineer
XING | LinkedIn
The problem is that there are no “ISO-SPLIT-POINT” in your PCF file.
In my opinion, the ISO-SPLIT-POINT are not properly positioned in the pipe line or are not connected to the pipe line objects.
I have tested with P3D 2022 and P3D 2025 no separation of the pipe line by the ISO-SPLIT-POINT.
Hartmut Eger
Senior Engineer
XING | LinkedIn
That is difficult to say, can you provide me with a model?
Hartmut Eger
Senior Engineer
XING | LinkedIn
