AutoCAD Plant 3D Forum
Isogen seem to refuse certain angles of piping
13 REPLIES 13
Message 1 of 14
hean117
2366 Views, 13 Replies
hean117
I am trying to generate an isometric drawing out of the piping shown in the picture. I know that in this case I probably should create an ortho view instead, but the customer wants isos... What to do...
The green part is generated fine when I try to pinpoint the problem using quick iso. The red part is impossible. The error log is completely clogged up with this message: "WARNING - The count of created skew entities is not correct." So, I guess it's a problem with the angle? When I use "offset angle" before I create the iso it generates. But I have to put in 30 (or so) degrees...
Got any ideas? I can understand that isogen can have difficulties with certain angles but this is ridiculous. By the way, I'm using Plant 3D 2016...
13 REPLIES 13
Message 2 of 14
h_eger
in reply to: hean117
h_eger
Can you please upload the PCF file.
Or the 3D drawing and details which project configuration Metric or Imperial.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 3 of 14
hean117
in reply to: h_eger
hean117
PCF file is attached.
As a sidenote I can say that it works like a charm in Plant 2017 with the exact same settings (just migrated the project). The customer wants it in 2016 though...
Message 4 of 14
ryan.bales
ryan.bales
Autodesk Support
Autodesk Support
I ran the PCF you attached in both 2016 and 2017 and they look identical.
Ryan Bales
Fusion 360 Product Support
Ryan Bales
Message 5 of 14
hean117
in reply to: ryan.bales
hean117
Something was wrong in the isoconfig file and I couldn't figure out what. I took a fresh file with the basic Plant settings in it and it worked. Then I had all the fuss with configuring everything again the way I wanted it. Now it works fine!
This is what sucks the hardest with this program. Just put all the controls in the GUI and this won't happen.
Message 6 of 14
ryan.bales
ryan.bales
Autodesk Support
Autodesk Support
I agree with you there. It would certainly make configuring the ISO settings far simpler.
Ryan Bales
Ryan Bales
Message 7 of 14
Dadspackard
Dadspackard
Hi
"Just put all the controls in the GUI and this won't happen"
If not already maybe this is something you can add to the Idea Station
Tom
Tom
aka, Dadspackard, Packin31
Hi
Tom
Tom
Message 8 of 14
in reply to: Dadspackard
I don't agree with "put everything on GUI",at least not now.
You see, what make isoconfig.xml so unfriendly is  WHER IS THE FXXXXXX MANUAL?? (look at AVEVA PDMS,the manual is too many to see them all)
As my opinion , using xml has its advantage now - very flexible to modify your iso,sometimes even looks like take advantage of programming bug.
If using GUI environment,what we can do is all determined by ADSK programmer. Then we take a look at P3D...well,from 2011 to 2017 ,still need to improve some very basic functions (even thought PDS, PDMS..etc. have already show them what abilities a plant design software should have.)
P3D make me feel like "We sell program first, then using then money to improve it step by step",but if a user can do all the thing on PDMS or other software,WHY SHOULD I CHANGE TO P3D? ( well....I know,I know ,because the owner force us to :[  )
Message 9 of 14
h_eger
h_eger
We can talk about your indifference! But we can not talk about your language skills in the forum. We are not here to have to read this! So moderate your spelling otherwise we will take initiatives against drolle grasped !!!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 14
in reply to: h_eger
I apologize for the inappropriate words I used.
Message 11 of 14
AHepker_HOB
AHepker_HOB
I find that digging into any software is the best way to make it work the way you want it to. Instead of focusing on the GUI, try digging into the xml. Every change I personally make is through the xml. Learned everything I know buy simply making a change in the GUI and comparing the original xml to the new one. It can be a labyrinth at times, but now that I'm familiar with it, customization comes quite easily. Ain't or changing filters, layer styles, dimension behaviors, etc. All very easy when you've spent time digging into the deep, dark depths of the Isoconfig.xml. How my two cents were helpful.
Check out our blog @ HouseOfBIM.com
Message 12 of 14
AHepker_HOB
AHepker_HOB
My phone typing skills are not up to part tonight. Sorry for the typos.
Message 13 of 14
in reply to: AHepker_HOB
I agree with you.Testing isoconfig.xml make me so crazy to said the crazy word. But xml also give us a lot of freedom and possibility of modifying iso than Isogen (which PDMS,PDS use). Here I apologize to ADSK again. You do a good work!
Message 14 of 14
AHepker_HOB
AHepker_HOB
I agree that the people over at Alias and Intergraph are doing a great job with Isogen, but I wouldn't say it's any easier. Their interface is robust to say the least, sometimes too much so. Plant is very simple to use and is still a young software with lots of room to grow. That coupled with the cost difference of the software and this excellent community that Autodesk has put together definitely pushes me towards Plant.
