AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Iso weld list edit
10 REPLIES 10
Message 1 of 11
652 Views, 10 Replies
Iso weld list edit
Hi everyone,
Im trying to edit my weld list:
Can anyone help me to split the list in the same page when list comes to the end of the area?
See the pics for more info.
10 REPLIES 10
Message 2 of 11
Bernd.Gerstenberger
Hello Nuno,
when you have the iso.dwt open like in your picture, then select the table and open the property palette. You will see here a section called "Table Breaks". Set property "Enabled" to "Yes". When change the break height. I have set it to 15. Look this snapshot:
Best regards
Bernd
Bernd G.
Senior Product Support Specialist
Message 3 of 11
in reply to: Bernd.Gerstenberger
Hello Bernd G.,
Thanks for your reply, the result isn't good yet,
see the pic.
Message 4 of 11
Bernd.Gerstenberger
Please, increase the value of the break height to show more than one row only. The break height defines when the table will be split.
Bernd G.
Message 5 of 11
It's already good... i'm having a problem when i increase the break height it doesn't fit all weld list, it creates me a new overflow page.
Can you help me?
Thank you
Message 6 of 11
Bernd.Gerstenberger
When you are in the iso.dwt, there is a blue hatch. This the table area. This area shows how many space is available for your table. You can increase this area by using the grips. Also you can move it if needed. Make the table area big enough that all fits on one sheet. If more rows are listed than it is possible for this table area, there are two possible behaviors: An overflow sheet will be created with just the additional rows of the table(s). Or the isometric drawing will be split, so that all shown geometries can be listed in the table of the same sheet. The wished behavior can be selected in project setup, node "Isometric DWG Settings - Iso Style Setup", frame "Table overflow".
Bernd G.
Message 7 of 11
I cannot understand why creates overflow sheet for weld list, because there are enough space to put into drawing sheet.
see the pics.
Thank you
Message 8 of 11
Bernd.Gerstenberger
Please, send me your iso template of the used iso style: by default it is named iso.dwt.
Bernd G.
Message 9 of 11
Hello
Did you receive my iso template?
Thank you
Message 10 of 11
Bernd.Gerstenberger
No, I haven't got it.
Bernd G.
Message 11 of 11
There it is.
Thank you
Technology Administrators
AutoCAD Beta
