AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Iso symbols on Vertical pipes
10 REPLIES 10
Message 1 of 11
olejnik
842 Views, 10 Replies
Hello Plant 3D Specialists,
I've encounter a problem with Iso Symbols on Vertical pipes, supports symbols to be more precise.
After creation and mapping many Iso Support Symbols I figure out that during testing the same symbol is shown differently on vertical pipes in the same pipeline.
I've search through forum but it seems that no one have similar problem, could you help me?
Best Regards!
10 REPLIES 10
Message 2 of 11
in reply to: olejnik
Check the direction in your properties for each support and see if they differ.
Message 3 of 11
jabowabo
Are these supports created with Python scripts?
Message 4 of 11
olejnik
For now I'm during testing and tailoring everything connected with iso generation, so I've used built-in supports and I didn't saw any option to change direction of support.
Message 5 of 11
jabowabo
To check direction, use the LIST command and see the Vector value.
Message 6 of 11
olejnik
Vector is the same for all vertical supports - 0,0,1.
Message 7 of 11
jabowabo
Also check the PCF files. Example:
SUPPORT
    CO-ORDS          748871.2556    456887.0704    1371.1875    2.0000
    SKEY  KP-MISCSUPT
    ERECTION-ITEM
    SUPPORT-DIRECTION  EAST
    PIPING-SPEC  PipeSupportsSpec2
    TRACING-SPEC
    COMPONENT-ATTRIBUTE1   INSULATIONTHICKNESS_0
    COMPONENT-ATTRIBUTE2   BOMCOLUMN_Material_
    COMPONENT-ATTRIBUTE3   BOMCOLUMN_HasChainwheel_
    COMPONENT-ATTRIBUTE4   BOMCOLUMN_ValveNormal_
    COMPONENT-ATTRIBUTE5   BOMCOLUMN_ValveTagAnno_
    COMPONENT-ATTRIBUTE6   BOMCOLUMN_TagAnno_
    COMPONENT-ATTRIBUTE7   BOMCOLUMN_InstrumentTagAnno_
    COMPONENT-ATTRIBUTE8   BOMCOLUMN_OrificeTagAnno_
    COMPONENT-ATTRIBUTE9   BOMCOLUMN_IsoNote_
    COMPONENT-ATTRIBUTE10   BOMCOLUMN_SpNumber_
    CONTINUATION
Message 8 of 11
olejnik
I've checked it all, and everything looks good, see attached screenshots.
Message 9 of 11
≡ EqVert ≡
this may depend on the direction of the pipeline. bottom to top or top to bottom
Message 10 of 11
olejnik
I've created another pipeline to verify that theory, and you are right - it depend on routing direction. As it turns out that also depend on type of iso creation method (Quick iso/Production Iso). Symbols that was correct on iso generated by Iso Production method appear as incorrect on iso generated by Quick Iso method and incorrect change into correct.
That knowledge is valuable but at the on of a day doesn’t change anything, because problem still persist, because routing only in one way up will be very very inconvenient, using two different symbols one for pipes routed from bottom to top and one for routed from top to bottom also sounds like way-around solution.
Do you have any ideas how to solve this issue in better way?
Message 11 of 11
≡ EqVert ≡
I think this should be added as a request for an idea. As far as I remember, in these blocks there is no support for dynamic operations, such as a mirror. That would sound like a workaround.
