Iso Errors - object reference not set to an instance of an object
autocad2
Message 1 of 19
autocad2
Please help i was generating isometrics with no problems then i started to get this error, can someone help to resolve please asap.
let me know if you need any more information.
Iso Creation start time : 01/05/2018 13:10:00
Iso Creation finish time: 01/05/2018 13:10:04
Duration : 00:00:04
Output folder : S:\Job Files\2018 Jobs\6389 18-01-7405 Wallwork pipework for Cambridge site\6389 - Wallwork pipework for cambridge\Isometric\Final_A3\ProdIsos\Drawings
1 Isometric(s) were not able to be created:
S:\Job Files\2018 Jobs\6389 18-01-7405 Wallwork pipework for Cambridge site\6389 - Wallwork pipework for cambridge\Isometric\Final_A3\PCFs\AR SUPPLY.pcf
INFO - Loading input: 'S:\Job Files\2018 Jobs\6389 18-01-7405 Wallwork pipework for Cambridge site\6389 - Wallwork pipework for cambridge\Isometric\Final_A3\PCFs\AR SUPPLY.pcf'
INFO - Loaded '1' model(s).
INFO - Processing: 'AR SUPPLY'.
WARNING - No break points have been specified.
INFO - Model-split has been skipped.
FAILURE - Object reference not set to an instance of an object.
Thanks Ryan
Replies (18)
Message 2 of 19
Dadspackard
Hi Ryan,
What version of Plant are you running?
Could you share your PCF file with us?
Would like to run here?
Tom
aka, Dadspackard, Packin31
Message 3 of 19
autocad2
hi tom,
i am using 2019 here is the PCF file for the AR supply line.
thanks ryan
Message 4 of 19
h_eger
Dear @autocad2,
please check your connections with your Piping Components.
Otherwise, I can also notice something conspicuous with the Line AR-SUPPLY
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 5 of 19
Dadspackard
Hi Ryan,
I am running Autodesk® AutoCAD® Plant 3D 2018.1.1 Update.
I imported your PCF into an new drawing (mmetric project) but since I dont have your specs it used PLACEHOLDER
METRIC and Custom Part Spec. I had to do some clean up to the pipe because there were some disconnects and for some odd reason some of the flanges flip 180degs.
As you can see by the attach ISOs I was able to run the pipe. I used the Plant 3D out of box Iso Style Final_A2.
Do you have any drips (disconnected pipes) in your model?
Tom
Message 6 of 19
autocad2
hi tom,
all connections are fine and i can also create isos using the default Fianl A2 but still not working for my custom setup as it was previous.
Any more advice.
Thanks Ryan.
Message 7 of 19
Dadspackard
Ryan,
Custom setup?
Can you elaborate more on what you mean by this?
What did you customize?
Tom
Message 8 of 19
h_eger
Dear @autocad2,
here is something wrong with your Iso config. Wrong SKEY or other settings.
Without a project, troubleshooting is almost impossible.
<!-- FAILURE - Object reference not set to an instance of an object. -->
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 19
autocad2
tom,
I have altered the iso style, annotations, dimensions, themes and title block in the project setup. As i said it was working earlier then i changed my title block and it started saying errors.
thanks,
ryan
Message 10 of 19
autocad2
would this help.
ryan
Message 11 of 19
Dadspackard
Ryan,
Did you happen to rename the block of the title block?
It needS to stay at tittle block.
Tom
Message 12 of 19
autocad2
The title block is still title block see attached image, i was changing the table colours so they were darker for printing.
ryan
Message 13 of 19
Dadspackard
Hi Ryan,
Was able to run one on my end with the project you posted.
I ran the pipe with your FINAL_A2 style
Tom
Message 14 of 19
autocad2
its the Final A3 style that is modified i can run the A2.
ryan
Message 15 of 19
Dadspackard
Hi Ryan,
Error
FAILURE - Unable to create isometric due to problems with the current Iso Style.
  '\\wel.local\dfsdata\RedirectedFolders\ryan.green\Desktop\Autocad plant 3d\DRAWING TEMPLATES\WALKER ENG ISO FINAL A3 LAYOUT.dwt' is missing or corrupted.
FAILURE - eFilerError
Is this your ISO border?
Tom
Message 16 of 19
h_eger
Dear @autocad2,
the problem is your Iso-DWT which seems to be incorrect in your Iso config.
Iso Creation start time : 01.05.2018 15:46:17
Iso Creation finish time: 01.05.2018 15:46:18
Duration                : 00:00:01
Output folder           : D:\Projekt\Technische P3D Projekte\2019\6389 - Wallwork pipework for cambridge\Isometric\Final A3 test\ProdIsos\Drawings
    D:\Projekt\Technische P3D Projekte\2019\6389 - Wallwork pipework for cambridge\Isometric\Final A3 test\PCFs\AR SUPPLY.pcf
AUSFALL - Isometrische Zeichnung kann aufgrund von Problemen mit dem aktuellen ISO-Stil nicht erstellt werden.
  '\\wel.local\dfsdata\RedirectedFolders\ryan.green\Desktop\Autocad plant 3d\DRAWING TEMPLATES\WALKER ENG ISO FINAL A3 LAYOUT.dwt' fehlt oder ist beschädigt.
AUSFALL - eFilerError
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 17 of 19
Dadspackard
Ryan,
By the way excellent pipe work you are doing there.
Tom
Message 18 of 19
autocad2
solved.
I created a new title block on the Final A2 and modified it from there.
Thanks for all your help,
Ryan
Message 19 of 19
Dadspackard
Ryan,
Glad to read you got it worked out.
If you need anything else please dont hesitate to ask.
Have a pleasant day or evening for you
Tom
