I have a problem with ISOmetric drawing, specifically with dimensions of supports. When there is more than one support in a row on one pipe, dimensions goes from fitting (let's say elbow) to last support, instead of first. To make it worse, dimension is over other support dimensions, so you can't notice it at first... This haven't happen to us before, and it is happening on every project that we are working at (even those that were working normally before, and we haven't modified the templates).
I tried modifying the settings of support dimensions, but nothing has helped.
Thanks in advance and best regards,
Danijel
Solved by jw7018. Go to Solution.
Fixed in newer releases. What version are you using.
This has been answered before:
