Hello Plant 3D community,
do you know that the isometrics are compressed when reference dimensions are inserted?
Does anyone have an idea how I can fix this?
here is an example:
here is an example:
Solved by viktor.teichrib. Go to Solution.
Solved by Tomislav.Golubovic. Go to Solution.
Plant 3D Version: 2024.1
I have set a manual break point. One iso looks good, the other doesn't. I then looked for which element in the bad iso is doing this.
It is the Olet element. The symbol type Type=PIPE is used for isometric creation and not Type=OLET
Thanks for the inspiration to set the break point.
