I created a project using sheet number in the line number tag and I get everything working like I want especially with the iso continuation text. The bad part is I have to create a new line number for every sheet number. So I copied the project and modified it where I don’t have sheet number in the line number tag. I added a sheet number field to the Piping and Equipment section of the P3D Class Definitions which allows me to break components into the appropriate sheet number. This way I will only have one line number no matter the number of sheets. The problem with this set up is the continuation text does not come out the same. Plus I am getting duplicate sheet numbers
Please see the two attached screenshots. The first one shows the continuation text I want yellow. The second one shows the continuation text in green which is what I do not want.
