AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Iso annotation enclosure - Flange, Bolt, Gasket
8 REPLIES 8
Message 1 of 9
jed_freeman
204 Views, 8 Replies
jed_freeman
According to 2025.1 update Iso annotation enclosures no longer revert after updating Project Setup. This has been a thorn in my side for a long time and I was excited to see that it is fixed...buuuuut, it still is not working correctly. I made changes to Project Setup and when i ran my iso sure enough the F, B, G enclosure is wrong...am I missing something?
8 REPLIES 8
Message 2 of 9
h_eger
in reply to: jed_freeman
h_eger
@jed_freeman ,
can you report this case to Autodesk Support You can also use this Case ID: 22187134 where this problem is described and also escalated to Autodesk.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@jed_freeman ,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 3 of 9
Michiel.Valcke
This might be a stupid question, but is the option to scale the rectangular enclosure checked?
Message 4 of 9
jed_freeman
jed_freeman
we tried using that option but it squeezes down the rectangle so much its harder to read...the designers hated it
Message 5 of 9
h_eger
h_eger
@Michiel.Valcke ,
no, this function should actually solve the problem, but it doesn't because when I activate the function scale the rectangular enclosure ALL enclosures are scaled, even the single-digit position numbers.
Hartmut Eger
Senior Engineer
XING | LinkedIn
@Michiel.Valcke ,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 6 of 9
DVaquand
DVaquand
Hello @jed_freeman
Is the setting of your Flange/Joint/Bolt annotation correctly aligned with a “SRectangle” frame?
== French ==
Le réglage de votre annotation Bride/Joint/Boulon est-il bien calé sur un encadrement "SRectangle" ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Hello @jed_freeman
== French ==
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 7 of 9
jed_freeman
jed_freeman
I have to constantly change it back to SRECTANGLE...it changes to RECTANGLE after exiting Project Setup. The only fix is to open the IsoConfig.xml and change the text.
so every time i go into Project Setup and make a change (not related to the enclosure) i have to edit the xml.
Message 8 of 9
h_eger
in reply to: DVaquand
h_eger
Hi Dominique,
yes, the value is set to ‘SRectangle’ but it is regularly changed to ‘Rectangle’ when changes are made in the P3D configuration.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hi Dominique,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 9
Michiel.Valcke
Sorry for misunderstanding at first, but from my end it is working, setup updates do not revert the SRectangle to Rectangle. So best to share your drawing/project with Autodesk and refer the case ID given by @h_eger
