AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Is Python Language used for Auto Plant 3D developing language? How should I start Learning Python language for Auto plant 3D?
7 REPLIES 7
Message 1 of 8
nilesh.shirsath
316 Views, 7 Replies
7 REPLIES 7
Message 2 of 8
h_eger
in reply to: nilesh.shirsath
Dear @nilesh.shirsath ,
Here is the link to David Wolfe Part 1 to Part 5
https://adndevblog.typepad.com/autocad/2015/06/custom-python-scripts-for-autocad-plant-3d-part-1.htm...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 8
nilesh.shirsath
in reply to: h_eger
Thank you for your suggestion but sir will you please suggest any training  from your side? It will  be very helpfull.
Message 4 of 8
h_eger
I don't know any more information. But I haven't searched other platforms for training for Plant 3D and Python
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 8
Your licensed Autodesk reseller might offer python plant 3d specific training, most don't. One place I was at did, but the training was less than 1/2 a day and didn't cover much.  Give them a call and see.
George
If my post offers a solution, please click "Accept as Solution"
Message 6 of 8
jabowabo
Your question is vague regarding your intent. Python is used for developing scripted content (3D piping items & equipment) for Plant 3D but is not of use for interacting with the application as with a plugin like the .NET API.
Message 7 of 8
nilesh.shirsath
in reply to: jabowabo
Thanks  for your reply, But I  need to customize plant 3D like below,
1) Write a Script for any kind of valve(control valve, on/off valve or any instrument) so that just by running that script I will get 3d model of that valve
2) Also for drafting any kind of orthographic  view on templet ,Drafting  isometrics on  templet.
3)OR write script for "Spec filling procedure" cause in current condition  we are filling  spec manually.
Will you please give training regarding  all these above mentioned issues,
Thank you.
Message 8 of 8
jabowabo
1. Python
2. .NET
3. .NET
As for training, I don't work in that profession. There are many online resources and some resellers that offer training can be found with a search.
