Is autocad 3d plant part of the design and manufacturing collection ?
Solved by TheCADnoob. Go to Solution.
IT appears that Plant 3D is part of the AEC collection
https://www.autodesk.com/collections/architecture-engineering-construction/included-software
Though im not sure if thats the only one its offered in.
CADnoob
CADnoob
Hello Bart,
theCADnoob is right. Plant is part of the AEC collection and this is the only collection where it is integrated. Look for the three available collections at this site at the top.
Please, mark our posts as an Accepted Solution if we could help you.
Regards
Hello Bart,
Regards
I know that this is an old thread and things have changed.
I run the design and manufacturing collection on 2017.
Do I now have access to Plant 3D? its says I do on 2019 but I only want to run 2017?
Warren.
Warren.
if you are a subscriber you may be able to get plant 3D with "Only one AutoCAD"
check the FAQ about transferring if not.
You also have rights to older versions but im not sure how it all relates to the new licensing
https://knowledge.autodesk.com/customer-service/account-management/users-software/previous-versions
CADnoob
CADnoob
