So, I have a model from a vendor. Property Value File Size 5,539,107
It's a Parasolid file exported as an X_T file.
I import it into Inventor and it renders and rotates smoothly with no lags, glitches or anything.
I import in into Plant3D and it's horrible.
Plant3D can't even move the file from its base import point without horrible soul crushing hangups and regens.
I'm told the AutoCAD engine inside Plant3D is not the same as the engine inside Inventor.
OK, so anyone in the know if Autodesk plans to replace the Plant3D engine with the Inventor engine?
Or is there any setting in Plant3D to improve this?
Thanks 🙂
How complex is this model? Skid with each and every nut and bolt, curves on everything?
Its AutoCAD, its a completely different engine to the other two, Revit and Inventor. If you want to bring them in you're going to have to shrinkwrap the Inventor models and take out the detail.
I've got models, and had clients with super detailed models in Plant 3D, and it just doesn't like the size/detail, and then when it comes to the Ortho, it takes forever. You have to take out the detail of it otherwise you'll be twiddling your thumbs a lot while the Ortho's generate.
