Insulation only shows on part of a line?
Paul.Carson4JXY2
Paul.Carson4JXY2
When I generate ISOs in Plant 3D 2023, sometimes the insulation only shows on part of the line.
I have to manually go into the ISO and redraw this, which is not ideal when there is a change.
Is there a known reason why this happens?
h_eger
@Paul.Carson4JXY2 ,
are your coordinates in the ISO relative or assigned via offset location?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Paul.Carson4JXY2
I've attached from the project setup.
We work with Navis so I take it this is relative? Most insulation works fine, its just the occasional ISO where this happens.
h_eger
Occasionally, the insulation may be displayed incorrectly during iso generation.
I have not yet found the reasons for this.
My workaround for this is to manually rework the iso.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Paul.Carson4JXY2
Thanks for the input, yes that sounds like what I'll have to do here.
h_eger
Can you please upload the PCF file of this iso (change file extension to *.txt) so that I can test it.
Hartmut Eger
Senior Engineer
XING | LinkedIn
