Instruments in BOM
Instruments in BOM
Message 1 of 24
Instruments in BOM
Hi guys!
Does anyone know how to make include control valves tags or family description in BOM on isometrics. Thnaks in advance.
Replies (23)
Message 21 of 24
I just tried this and it needed some typo corrections, but worked in 2017. I simply do not know why there isn't a switch in Project manager for this????
I have added some pre and post text to help you find it in your own XML file, but the corrected code which works for me is in red. The older posts has spaces and some coding missing.
Hope this helps.
        <ComponentScheme Name="BendRadius" AnnotationStyle="Standard" Format="Bend Radius {0}" Enabled="false" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="Bend" Fields="BEND-RADIUS" />
          <ComponentScheme Name="Instruments" AnnotationStyle="Circle" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="Always" Components="Instrument" Filter="Instrument" Fields="PartNumber" />
<GroupScheme Name="FlangeGroup" AnnotationStyle="SCircle" Enabled="false" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false">
         <Group Name="PIPE SUPPORTS">
            <RowFilter Filter="Support" />
            <Labels>
              <Label Name="pipe supports" />
            </Labels>
            <Columns>
              <Column Name="Category" />
              <Column Name="Code" />
            </Columns>
            <Sort SortBy="Type ASC,ConnectionSize ASC" />
            <Precisions />
          </Group>
<Group Name="Instrument">
            <Labels>
               <Label Name="instrument" />
            </Labels>
              <Columns>
              <Column Name="Category"/>
              <Column Name="Code"/>
            </Columns>
            <Sort SortBy="Type ASC,ConnectionSize ASC"/>
              <RowFilter Filter="Instrument"/>
          </Group>
        </Groups>
Message 22 of 24
cadVVUC8
Has anyone figured out how to do this when using shop/field type material list, where you can't copy the 'valve' rows'?
Message 23 of 24
cadVVUC8
Doesn't matter, all sorted.
Place the same code in the next paragraphs.
Message 24 of 24
jw7018
How to get a custom part to show up in BOM or MTO.
This is only a quick fix:  I had to change the SKEY to an existing threaded component (like a union)
OPTION 1.
(recommended)
adds to BOM and places a square in the ISO model space
SKEY=SGSC,TYPE=MISC-COMPONENT
OPTION 2.
Made smart plant components
I have made PI, TW< & PITs
Gave them all union SKEYS
The part came into the BOM with my custom description
