AutoCAD Plant 3D Forum
Instrument Iso Annotation on Olet Branch
3 REPLIES 3
estamoulis
292 Views, 3 Replies
I have a problem to annotate an instrument in my isometric. If the branch starting with a stub in pipe are ok, the instrument annotation is visible. If the branch starting with olet the annotation is ....invisible. Any ideas??
3 REPLIES 3
h_eger
in reply to: estamoulis
Dear @estamoulis ,
I can't find any problems with Instruments directly to Olet and output to Iso.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jabowabo
Annotations are applied per whatever Theme is acting on the section of piping. You'll need to turn on this (or all) annotation(s) for this specific Theme.
estamoulis
Thanks for replies.....
The situation is solved if disable the "offline instrument connection'' theme from branch piping
