AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Inline instrument connection with S.W Flanges
8 REPLIES 8
Message 1 of 9
mohammedhewieg
292 Views, 8 Replies
How to connect an inline instrument like a magnetic flow meter to a S.W flange while giving no error message
what are the appropriate specs?
8 REPLIES 8
Message 2 of 9
h_eger
in reply to: mohammedhewieg
Dear @mohammedhewieg ,
the error description is a bit thin, but if the end connections are configured correctly, it works very well.
PS. Which error message?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 9
mohammedhewieg
in reply to: h_eger
Error: Cannot connect parts. Flanged connection failed due to the properties mismatch. E1.NominalDiameter=E2.Nominal Diameter AND E1.PressureClass-E2.PressureClass"
this is the error that appears when i try to connect S.W flange to an inline instrument such as flow meter how can i solve it ?
Message 4 of 9
h_eger
Which units are you working with in this AutoCAD Plant 3D project?
Are the components in the pipe specs all in the same unith mm or inch?
Are the connections of your components all identical?
NominalDiameter
PressureClass
SW flange and inline instrument?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 9
mohammedhewieg
in reply to: h_eger
i am working on spec 300
flow meter and S.W Flanges are the same
Message 6 of 9
h_eger
Attention!
SW flanges are only available up to 1 1/2" or DN40
Therefore you will get an error message if you move outside the Nominal Diameter Range
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 9
mohammedhewieg
in reply to: h_eger
How to choose a spec contain a s.w flanges contains all size?
Message 8 of 9
h_eger
SW flanges are only available up to 3" or DN80 according to ASME B 16.5
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 9
mohammedhewieg
in reply to: h_eger
thanks for the clarification
