I made custom ISO style but now getting error when using it
shadow931
Message 1 of 8
shadow931
I am learning how to create an ISO template but it's complicated at least for me and what I managed to do is giving me errors. I can't find a source to learn from I only find partial tutorials which are incomplete.
This is how my block looks like:
And here is the error. If you know a good place to learn how to do these templates it will help me. Thank you.
Iso Creation start time : 28.6.2018 г. 14:00:55
Iso Creation finish time: 28.6.2018 г. 14:02:37
Duration                : 00:01:42
Output folder           : D:\BBS\For3dplant\ForrEmerald2018\Isometric\MSS\ProdIsos\Drawings
1 Isometric(s) were not able to be created:
D:\BBS\For3dplant\ForrEmerald2018\Isometric\MSS\PCFs\BW01-01.pcf
INFO    - Loading input: 'D:\BBS\For3dplant\ForrEmerald2018\Isometric\MSS\PCFs\BW01-01.pcf'
INFO    - Loaded '7' model(s).
INFO    - Processing: 'BW01-01-1'.
WARNING - No break points have been specified.
INFO    - Model-split has been skipped.
WARNING - Invalid filter expression: 'Existing = 'false' AND SpoolNumber <> '''.
INFO    - Processing: 'BW01-01-2'.
INFO    - Processing: 'BW01-01-3'.
INFO    - Processing: 'BW01-01-4'.
INFO    - Processing: 'BW01-01-5'.
INFO    - Processing: 'BW01-01-6'.
INFO    - Processing: 'BW01-01-7'.
FAILURE - eKeyNotFound
Replies (7)
Message 2 of 8
DGRL
Dear @shadow931
You need to specify a specific made eKEY you used for i guess a valve
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Message 3 of 8
DGRL
or you used tag inside your template that are not registered inside the *.atr file of your  theme
Kind Regards
Message 4 of 8
shadow931
Thank you but I have no idea what ekey or not registered tag mean.
Message 5 of 8
DGRL
hi @shadow931
Maybe you can upload the pcf file of the pipe
(make it a zip file)
Kind Regards
Message 6 of 8
shadow931
I created a new ISO template and that problem got fixed but I have two other problems now.
1. When I copy the folder with the Iso Style to another computer I get an error saying the path to the folder does not exist but it is looking for the path that was on the computer that created the Iso Style and not for the path on the new computer.
2. The block attributes like Date, DWG number, current page, that are supposed to be written by the program does not work
Message 7 of 8
DGRL
@shadow931
Do you work on a network?
Kind Regards
Message 8 of 8
shadow931
Yes I work with other people and we have LAN between our PCs but we don't use tools to share projects like vault or similar. We just copy the drawings or projects over the LAN when necessary.
