AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to transfer SQLITE to SQL SERVER(VAULT)
6 REPLIES 6
443 Views, 6 Replies
85180200
I 've created a project on vault by plant3d,after that i created several file folders on plant3d,and then i moved the 3d-model folders to some other places on vault,all seemed very nice! But,somedays ago,i can't import dwgs to vault,the button were all grey,i found that databes was on the SQLITE  not SQL server.I tried to delete the project file folder on one computer,and then retreated the project fles on vault,but the file folders i've moved to another place can't come to the computer,and i also can't use the project any more.Will you please tell me how could i do? i really don't
 want to create new project anymore!
6 REPLIES 6
MateusMaciel
in reply to: 85180200
in reply to: MateusMaciel
85180200
Thank you very much but i failed .i can‘t  open the settings of the project, i clicked the button, but it showed nothing to me.it was grey!
MateusMaciel
MateusMaciel
I didn’t understand, Which stage gave you a problem?
mateustilapa@gmail.com
85180200
the project was on vault already,i tried the method you told me,and the route i chosed the same on vault,and it seemed very well。After doing that,i lanched plant3d,it warned me the .xml files can be read only,i changed that ,and then lanched plant3d another time,but the peoject setting button was grey,also the vault function .Thank you for your help
85180200
85180200
Do you know how to do ?if not i will creat a new project.😓Thank you all the same !i've met this problem many times. the database always came to sqlite ,i don't know why and how to aviod this!
