How to show threaded open end in SPOOL ISO?
santoshbaraiya
santoshbaraiya
I have a pipe connection that is open and the pipe is threaded at the end. That end is going to be connected to the equipment and I want to show the end of the pipe is threaded in ISO drawing. Is there anyway to put the threaded end joint (that red point) in the model so that it will show the threads on the iso drawing?
Michiel.Valcke
The cleanest way is to add a pipe to your catalog & spec, that has one port as PL and one port as THDM. start with a THDM pipe so the end treatment is included in the shape. Set the L1 property of the PL port to -2 so the threaded feature won't be generated there.
Then do a spec update and replace your pipe with the new one.
