AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to show the fixation bolt in structure
2 REPLIES 2
faragello
659 Views, 2 Replies
Hello All
I working in platform drawing using plant 3D, I need to show the installation point like bolts and anchor bolts, and also I want to add the bolts to show it in BOQ how can I select specific types what am I using? thanks to all
2 REPLIES 2
h_eger
in reply to: faragello
Dear @faragello ,
Not at all there these special functions are not available in the Plant 3D structure.
For this you can use programs that master the detailing of the steel structure such as Advance Steel or Revit Structure.
Plant 3D Structure is intended for pre-planning and space planning, but unfortunately not for detailing.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
faragello
thank you for your replay,
