How to properly call a python file from another python file to make an Assembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Ma'am/Sir, It's me again, Sorry I have no where to go, this forum is the only way for me right now to gather information for development of support customization in plant3D through python scripting, since I cannot find any company here in the Philippines that cater such training. I really need help. I created five python file which containing a script for custom support parts and added it inside Plant3D through spec editor, which is a success. Also I created again a python file which I use to call the five python support parts using this line of codes (from PSL_PC3_CSR1 import *), to make a one support assembly, and added it also on my spec to be used inside plant3D, which is also a success the parts is now assembled in one python file. now the problem is, I added a "s.setLinearDimension" on my python support assembly so that it will have a grip point inside Plant3D, After placing it inside Plant3D for testing, the grip point is there, but unfortunately when I try to adjust it support length using the grip point it did not work, but when I try to create a rod only on another python file, meaning cylinder only with default length and added the "s.setLinearDimension" on it, the grip point work it adjust inside plant3D. I don't know how I will gonna apply the "s.setLinearDimension" on a python file that consist of many parts as a assembly. I attached a screenshot of my python script below, because I cannot paste it here(I don't know why). but please check my script below. I will really appreciate your help Ma'am/Sir's and I will be forever grateful. thank you in advance.
