AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to open a file from 3D plant in normal autocad?
4 REPLIES 4
kolap274
245 Views, 4 Replies
Hi guys!
I am having trouble opening my .dwg file made with Plant 3D in normal autocad , pipes do not show properly and components are missing , any idea how to solve it ? thanks in advance
How it should be
4 REPLIES 4
jabowabo
in reply to: kolap274
kolap274
in reply to: jabowabo
Computer is not mine , I am not able to install anything on it . Another solution?
h_eger
Dear @kolap274 ,
No, that is the only solution @jabowabo has proposed!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@kolap274 if you want only solid model then export the model form plant 3d into dwg format, then open it in cad.
