Hi all, might be a silly question, but how do I launch Plant3D actually, from AutoCAD? I have AutoCad 2024:
I only have one executable (acad.exe). Then what? I only have the workspaces for 2D drafting and 3D.
It says that it should be included in the AutoCad. But I don't know how to actually launch the Plant3D.
Thank you in advance!
Solved by mtj73RN9. Go to Solution.
Autocad Plant 3D is a separate program.
The image you show says it's gives you access to it.
You should be able to download it from manage.autodesk.com - otherwise contact the one who is administrator in your company. Under "Custom install" you can create a new package, then you select the different programs you need, then create and download.
Thank you very much! I assumed they were unified in one application. I installed Plant3D successfully 🙂
