AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to get rowid of from P3dLineGroup table?
12 REPLIES 12
Message 1 of 13
salman_abeed
488 Views, 12 Replies
I am trying to create new piping components into the model and want to assign a line that I am reading from excel. I check if a line already exist then try to get the rowid otherwise create a new line and then create a relation.
Issue is that query to search existing line is not returning any results. Here is my sample code
PlantProject currentProj = PlantApplication.CurrentProject;
PipingProject pipeProj = (PipingProject)currentProj.ProjectParts["Piping"];
DataLinksManager dlm = pipeProj.DataLinksManager;
PnPDatabase db = dlm.GetPnPDatabase();
PnPTable p3dLineGroupTable = db.Tables["P3dLineGroup"];
string lineFilter = string.Format("Number='{0}'", lineNumber);
PnPRow[] rowsLines = p3dLineGroupTable.Select(lineFilter);
int lineRowID = 0;
if (rowsLines.Length > 0)
    lineRowID = rowsLines[0].RowId;
12 REPLIES 12
Message 2 of 13
h_eger
in reply to: salman_abeed
@salman_abeed ,
rowid is NOT the row number in the DB!
The rowid is used to link information between the tables.
Here is the structure of the Piping DB to study and understand
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 13
salman_abeed
@h_eger thanks for the reply. Can you tell how can I search the ID of exisiting line to create the relation of line with a new component?
thanks
Salman
Message 4 of 13
jabowabo
Try this:
string lineFilter = string.Format("\"Number\"='{0}'", lineNumber);
Also, it's better practice to search for the Tag rather than Number, as Tag must be unique but Number does not.
Message 5 of 13
salman_abeed
No it still doesn't work. I try with tag as well and also putting field name in quotes but same result. If I try to add the same line again I get the exception
Message 6 of 13
jabowabo
I just ran a test with your exact original code and it worked with no problem.
Message 7 of 13
salman_abeed
I have attached my ProcessPower.dcf file in the zip format. I also notice in the new project it works fine but then later it starts failing. Not sure if this file alone will be enough. But can you give it a try?
thanks
Message 8 of 13
salman_abeed
Sorry I want to attach 3d database ... here is piping
Message 9 of 13
jabowabo
The ProcessPower.dcf you attached is the database for P&ID drawings. Piping.dcf is for 3D. Your code is querying the 3D piping database. Which database rows are you looking for?
Message 10 of 13
salman_abeed
in reply to: jabowabo
right I attached piping.dcf as well
Message 11 of 13
jabowabo
From what you've provided so far, I can't diagnose the problem. You'll need to provide more details, like variable values at each step, error messages, etc. for more help.
Message 12 of 13
salman_abeed
lineNumber variable value = CWS-1001
Message 13 of 13
jabowabo
That value does not exist in the database you provided.
