How to display the unit weight of pipe fittings in the material list (BOM)
z.kusztal
Message 1 of 10
z.kusztal
Hello
I have a problem
Replies (9)
Message 2 of 10
h_eger
Dear @z.kusztal,
for Isometry or Ortho?
Plant 3D Version ?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 10
z.kusztal
for izometry 🙂
Message 4 of 10
patpat79
Hi, good day. If what you want is to have a field in the Isometric BOM that will show both Piping and Fitting weight, you can create a new property using plantdefinecalcproperties command that will carry the property/value of weights of the piping, fittings, valves and then use that on your BOM table. Many thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Message 5 of 10
z.kusztal
I wants to display unit weight, elbows, tees, reducers conc ..... in BOM
Message 6 of 10
h_eger
Dear @z.kusztal,
the Weight column in the Iso configuration under BOM list should be added.
This works with all registered weights in the pipe specs.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 10
z.kusztal
It's about displaying Unit weight (item weight)
Message 8 of 10
h_eger
Dear @z.kusztal,
show me the field (item weight) which you have integrated into the BOM.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 10
z.kusztal
Message 10 of 10
h_eger
Dear, @z.kusztal,
since you have something misunderstood, the single weight are not represented in the database.
In your case everything is correct.
Linear Weight is only for pipes.
Hartmut Eger
Senior Engineer
XING | LinkedIn
