Message 1 of 10
- Mute
- Permalink
- Report
Hello
I have a problem
How to display the unit weight of pipe fittings in the material list (BOM)
Hello
I have a problem
Dear @z.kusztal,
for Isometry or Ortho?
Plant 3D Version ?
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hi, good day. If what you want is to have a field in the Isometric BOM that will show both Piping and Fitting weight, you can create a new property using plantdefinecalcproperties command that will carry the property/value of weights of the piping, fittings, valves and then use that on your BOM table. Many thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Dear @z.kusztal,
the Weight column in the Iso configuration under BOM list should be added.
This works with all registered weights in the pipe specs.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear @z.kusztal,
show me the field (item weight) which you have integrated into the BOM.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear, @z.kusztal,
since you have something misunderstood, the single weight are not represented in the database.
In your case everything is correct.
Linear Weight is only for pipes.
Hartmut Eger
Senior Engineer
XING | LinkedIn
