How to decomplied pyc to py ?
phantri.bl
Message 1 of 8
phantri.bl
Hello everyone.
How to decomplied pyc to py to read code ?
I used this sofware but it's not working.
Can you guide me ?
Thank you.
Replies (7)
Message 2 of 8
George.Endrulat
We use uncompyle6.exe
Essentially:
C:\>C:\Users\Username\AppData\Local\Programs\Python\Python38\Scripts\uncompyle6.exe -ro c:\Path\supportssub c:\Path\supportssub
If you change the Username, Path to reflect your setup that'll decompile supportssub/*.pyc to .py
Uncompyle6 convert pyc to py file python 3 (Whole directory) - Stack Overflow
George
If my post offers a solution, please click "Accept as Solution"
Message 3 of 8
h_eger
Dear @phantri.bl ,
click on "Decompile a Direct ..."
select your directory
and drink coffee it can take a little longer depending on the number of * .pyc files
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 4 of 8
phantri.bl
It is not working sir. It have a error : Magic value mismatch!
Message 5 of 8
phantri.bl
Sorry sir.
How to install uncompyle6.exe ?
How to use uncompyle6 ?
Can you make a video tutorial about install and use uncompyle6 ?
and give me a link to watch for more clearly.
Thanks sir, I'am try to learn.
Message 6 of 8
George.Endrulat
Go get the master branch from GitHub - rocky/python-uncompyle6: A cross-version Python bytecode decompiler
after you've installed python...
In the extracted zip directory
$ pip install -e .  # set up to run from source tree
                    # Or if you want to install instead
$ python setup.py install
 I've already shown in the previous post how to use it.  There's also a built in help.
George
Message 7 of 8
李榕华|Ronghua.LI
You can try this website.
https://tool.lu/pyc/
李榕华
13489140049@qq.com
Message 8 of 8
phantri.bl
Thanks Sir. I can decomplied easily.
