HOW TO CONTROL THE SIZE OF ITEM MARKS ON ISOS
adolfo_reyes
adolfo_reyes
The item marks in the isos is showing too small (see image attached).
how can i increase the size or the number and the square?
rajendra.prajapat
Change the symbol as per your need in IsoSymbolStyles dwg loated in isometric folder.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
MateusMaciel
@adolfo_reyes, the image with the example of the problem ended up not entering the post.
According to the image "text.png", to increase the text size, follow the following configuration:
1- Access the Project Setup;
2- Select the configuration:
Isometric DWG Settings \ Annotations
3- Select the isometric template you want to change
4-Enter the value of the text size you want in "Height and enclosure"
mateustilapa@gmail.com
adolfo_reyes
Hello, thanks for you reply. How exactly do I modify the file IsoSymbolStyles dwg?
Regards
rajendra.prajapat
@adolfo_reyes HI , go in to dwg & edit the respective block & save the dwg.
