Adding nozzles to Horizontal Centrifugal pump
Hi Folks,
Is it possible to add extra nozzles to standard horizontal centrifugal pump equipment ?  For example Pump casing drain, vent etc......I don't want to be creating a special equipment just for this......we all know that pumps come with more nozzles than Suction & Discharge, so I'm hoping it's a simple thing that I'm missing...…..other CAD platforms allow additional nozzles to be added easily.....so if it's not as simple as that, could Autodesk add this as a fix ?
Cheers
h_eger
Dear @Anonymous ,
we will not provide any additional connections for parametric pumps!
This is only possible with user-defined and block-based pumps.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
George.Endrulat
Create the pump parametrically, explode it, convert it back to a plant3d equipment, now you can add additional nozzles.  You do lose the parametric properties of the pump, but it does work.
George
If my post offers a solution, please click "Accept as Solution"
Cheers George, seems like this is the best way to get around Autodesk not allowing additional nozzles to be added
Hi Hartmut,
A bit poor that from Autodesk really.  Additional nozzles can be added to other parametric equipment like exchangers and vessels, pumps should be the same.
George.Endrulat
Yep.  We all know that no CAD problem is going to stop a deadline, work has to get done.
George
Yep, bang on the button there George......however faffing about to make things work shouldn't be a requirement, and affects estimates/schedule/quality/efficiency
