AutoCAD Plant 3D Forum
How to connect a vlave under slope to a nozzle
4 REPLIES 4
DGRL
362 Views, 4 Replies
DGRL
Dear forum members
I am trying to connect a valve with slope to a nozzle on a tank but i get the error "the ports must be adjacent in order to connect"
I already modified the DefaultConnectorsConfig but without any luck
What do i need to alter for this to work?
The slope is 1:40 so not really that big
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Dear forum members
Kind Regards
4 REPLIES 4
in reply to: DGRL
In these situations I move the valve out so nothing is connected to it and then grab one of the end grips and snap it back into the line. This will automatically align it to the pipe it is connecting to.
DGRL
DGRL
@Anonymous
Placing a valve in a pipe is no issue at all
Placing it agains a tank nozzle is a different story
Kind Regards
@Anonymous
Kind Regards
in reply to: DGRL
Oh I see. In that situation I would either have the valve square to the nozzle with the piping then having the fall away from the valve, or have a custom nozzle that has the fall built into it.
With a reasonable slope of 1:40 then I would go with the custom nozzle as that is what they would likely have to do when fabricating it.
DGRL
DGRL
@Anonymous
Thanks for your advise
It seems better to also place the tank nozzle under the needed slope
Kind Regards
@Anonymous
Kind Regards
