I want to model Piping in Plant 3D in elevation view. But when I go to side view, I see all the equipment and pipes. How can I clip the area I want to work in and model piping in elevation view?
Seem like duplicated with this: https://forums.autodesk.com/t5/autocad-plant-3d-forum/autocad-plant-3d-view-clipping/td-p/7300605
Don't clip, but use the HIDEOBJECTS/ISOLATEOBJECTS commands and the UNHIDEOBJECTS command to make items visible again.
You can also put the layer of those items on/off
Or if you're using a good xref structure, you can unload the relevant xref.
