How to change to a new Origin
abdelhalim.bousmaha
abdelhalim.bousmaha
I received a big project (with several xref) that I have to finish, but the client changed the Origin Smiley Frustrated  Is there a way to change it to the new one without moving and rotating all the Model and the xref?
Thank you 😉
h_eger
Dear @abdelhalim.bousmaha,
No, unfortunately not.
New CAD zero point means all models on it convert and check the connections!
If it is only about the Iometric Coordinates you can change them in the Iso generation
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
abdelhalim.bousmaha
OK Thank you @h_eger
I will move manually Smiley Sad
Ruffy85
use a excel sheet for importing all XREFS, there you can enter the location for insertion as well, move all xrefs to that point.
abdelhalim.bousmaha
Thank you @Ruffy85  for your reply, I moved all the drawing manually, I will try your solution next time or in a test project .
Thank you Smiley Wink
