How to add more properties/ custom properties on Data Manager Columns? Can I add layer as another column in data manager?
- Mute
- Permalink
- Report
Hi community,
Is it possible to add more columns in Data manager?
I am wondering if I can add a column such as Insulation Type and Insulation Thickness in the data manager for Pipe Run Components?
Currently, I can only view Insulation Type and Insulation Thickness under Pipelines which that is the Pipeline Group property. It would be really helpful to see the said properties on each component as there are pipes that has sections where insulation is not necessary and has to be removed.
Additionally, I wonder if it is possible to add a "Layer Column" in data manager? It will be helpful so that layers can be reviewed faster.
Your response will be greatly appreciated.
Thank you very much.
Ian
