AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to add a Flange wrap/Splash protector to Isos
1 REPLY 1
brantgriner
68 Views, 1 Reply
So I have a pipe system I am Re-designing and the new pipe spec calls for Flange Guards/Splash Guards to wrap around every flange. The pipe system is Lined pipe and is already very complicated for me to have everything come out correctly but I need to know how can I add these attachments and have them show the correct flange size on my isometric. The flange Guards will need to appear in the same way as the gasket for each flange does. Any suggestions?
1 REPLY 1
h_eger
in reply to: brantgriner
Dear @brantgriner ,
There is only one work a round for this.
Since the PCF standard does not provide for such a component and there is no such geometry in the Plant 3D content, the only way is to use a fastener and include it in the flange connection with a text description.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
