AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How can I get objects with a nozzle tag?
0 REPLIES 0
Message 1 of 1
traiduong014969
133 Views, 0 Replies
Hi All,
Recently, I found some information from the nozzle in the equipment. For example, I found the Nozzle tag from the equipment. However, I can't select it to zoom in on the nozzle with this tag. Could someone help me fix this code or provide suggestions?
Thank you !
This is my code
private static List<ObjectId> GetObjectsWithNozzleComponentTag(string nozzleComponentTag)
    List<ObjectId> objectIds = new List<ObjectId>();
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
        BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord;
        foreach (ObjectId objId in btr)
            DBObject dbObj = tr.GetObject(objId, OpenMode.ForRead);
            if (dbObj != null && dbObj is BlockReference blockRef)
                using (EquipmentHelper eqHelper = new EquipmentHelper())
                    var equipInfor = eqHelper.RetrieveEquipmentFromInstance(blockRef.ObjectId);
                    if (equipInfor != null && equipInfor is EquipmentType eqType)
                        var nozzles = eqType.Nozzles;
                        if (nozzles != null)
                            foreach (var nozzle in nozzles)
                                var tagProperty = nozzle.PortProperties.FirstOrDefault(prop => prop.Name == "Tag");
                                if (tagProperty != null && tagProperty.Value == nozzleComponentTag)
                                    objectIds.Add(objId);
                                    break;
        tr.Commit();
    return objectIds;
0 REPLIES 0
