Solved by TomislavGolubovic. Go to Solution.
Solved by patpat79. Go to Solution.
As far as i know, Plant 3D structural plates are for polygons only via polyline if custom polygon is needed. As a work around, you can just use presspull or extrude command. Thanks, hope it helps.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Try a 100 sided polygon, that'll convert to a plate.
That looks like almost a circle, i think its the answer you are looking.
Best Regards,
Pat Andres
GHD Manila
I had the same issue. To make it work I used round bar from the DIN Catalog.
The piece I needed was Dia 190mm x 12mm thick.
This is what I came up with:
ACPPSTRUCTUREBEAM Layer: "Structural Steel"
Space: Model space
Handle = 92cd
Member:
Start point: x=-4666.9106,y=12824.9727,z=125.2003
End point: x=-4654.9106,y=12824.9727,z=125.2003
Length/System length: 12/12
Material: A242
Shape size: Round/Round 190
you can turn into plate any polyline. i have half-circular platforms on some on my big sized vessels, just create a closed polyline and then create a plate.
