Hot to convert from NWD to DWG
rugsr7
rugsr7
I was given a NWD file and I want to bring it into my AutoCAD drawing. Then save it so it can be xrefed into another model.
I tried to open the NWD and export as a DWF/DWFX and even a FBX but when bringing it into AutoCAD it says theres errors. Thanks
matt.worland
You should be able to bring the NWD in as a Coordination Model. This treats it as an xref so you can view the NWD in AutoCAD.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
rugsr7
Seems like this way doesnt allow for 2d wireframe viewing
rajendra.prajapat
@rugsr7export the NWD as FBX file & import it in AutoCAD.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
AndyDavisArkance
FBX import/export was removed from AutoCAD in the 2019 version.
There is no direct way to convert  Navisworks geometry to AutoCAD geometry - Navisworks models are intended to be used for viewing and coordination rather than modelling.
That said, you could try using 3DS Max.  Export from Navisworks to FBX, import the FBX into 3DS Max then export to DWG.
Andy
Andy Davis
Industry Specialist
ARKANCE
