Hi All,
Through my company I purchased AutoCAD 2018 English from their list of available software. I want to generate several P&IDs and it looks like the Plant 3D toolset is suited for that. I cannot locate Plant 3D as an add-in or anywhere on my computer.
Does anyone else have AutoCAD 2018 with the Plant 3D Toolset? If so, can you advise how it get it running?
The AutoCAD website says the toolsets are included in AutoCAD One. What is AutoCAD One and how is it different from AutoCAD 2018?
Jack
Solved by pendean. Go to Solution.
Solved by DarrenP. Go to Solution.
here is the faq for autocad one: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Only-One...
it is just 1 license for the autocad based products except civil 3d
you still have to download/install each product
i do not know what you bought i will recommend going over with your reseller on what you bought
DarrenP
