- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I'm having a problem with my 2025 version of Plant 3D. When creating a new grating the hatch style selection menu is empty. I can still create it, and it will be created with the 'net' hatch pattern, but there again the other styles are missing from the drop down menu when I check them in the properties palette.
I've checked the acad.pat and acadiso.pat files, and they are in the correct location and their contents seems ok. I have tried resetting Plant 3D to default settings and reïnstalling, without any succes. The problem also occurs on other workstations. So I don't think it is a windows or user profile issue.
Before I contact Autodesk help, did any of you have the same experience? have you reported or solved it? or do you have a workaround until it is fixed?
