Graphically pipe connection to flange shown differently
PatrickByrne
PatrickByrne
As you can see from the attached picture I have a pipe connection done with two different specs one shows the pipe extending into the flange while the other shows the pipe finishing at the back of the flange. The end point of both pipes is the same, it’s just graphically they are shown differently.
Has anyone come across this previously.
jabowabo
Is the EngagementLength property the same from End2 on both flanges?
PatrickByrne
That’s where the problem was. In port 2 one of the flanges had an engagement length and no thickness.
I will further investigate the difference why there was no thickness.
