Is there any provision to generate the tag of support that will generate in isometric?
Solved by h_eger. Go to Solution.
Dear @chetan.sakure ,
Question for understanding:
Do you want the Piplinesupport TAG to be displayed on the isometry?
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Please check in your ISoConfig.xml if your entry is like this
<ComponentScheme Name="SupportStandard" AnnotationStyle="Standard" Format="{0}" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="Support" Fields="TAG" />
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear Mr. Eger,
I followed your instructions and changed my configuration as it is shown in Picture 1.
However, when I run my ISO, there is no TAG information for the support, as it is shown in Picture 2. I have a tag for each support (as it is shown in Picture 3).
I am using Plant 2023. Is this a bug for the version 2023 or I am missing something here?
Dear @bojan.caric ,
As long as your support tag contains a "?" no value will appear in the iso.
Please correct the tags for the supports then it will also work with the labelling in the iso.
Hartmut Eger
Senior Engineer
XING | LinkedIn
