Framework Error in Spec Editor
- Mute
- Permalink
- Report
Hello all
While working with the Spec Editor, the program is constantly closed. The logs contain the following errors:
Log Name: Application
Source: .NET Runtime
Date: 13/01/2021 13:16:03
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: -
Description:
Application: SpecsAndCatalogsEditor.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Runtime.InteropServices.COMException
at System.Runtime.InteropServices.ComTypes.IDataObject.GetData(System.Runtime.InteropServices.ComTypes.FORMATETC ByRef, System.Runtime.InteropServices.ComTypes.STGMEDIUM ByRef)
at System.Windows.DataObject+OleConverter.GetDataInner(System.Runtime.InteropServices.ComTypes.FORMATETC ByRef, System.Runtime.InteropServices.ComTypes.STGMEDIUM ByRef)
at System.Windows.DataObject+OleConverter.GetDataFromOleHGLOBAL(System.String, System.Runtime.InteropServices.ComTypes.DVASPECT, Int32)
at System.Windows.DataObject+OleConverter.GetDataFromBoundOleDataObject(System.String, System.Runtime.InteropServices.ComTypes.DVASPECT, Int32)
at System.Windows.DataObject+OleConverter.GetData(System.String, Boolean, System.Runtime.InteropServices.ComTypes.DVASPECT, Int32)
at System.Windows.DataObject+OleConverter.GetData(System.String, Boolean)
at System.Windows.Clipboard.GetText(System.Windows.TextDataFormat)
at Autodesk.ProcessPower.PnP3dSpecAndCatalogEditorUI.CatalogProperties.CanPaste()
at Autodesk.ProcessPower.PnP3dSpecAndCatalogEditorUI.CatalogEditor.CanPaste()
at Autodesk.ProcessPower.PnP3dSpecAndCatalogEditorUI.Window_SpecAndCatalogEditor.CanPasteHandler(System.Object, System.Windows.Input.CanExecuteRoutedEventArgs)
at System.Windows.Input.CommandBinding.OnCanExecute(System.Object, System.Windows.Input.CanExecuteRoutedEventArgs)
at System.Windows.Input.CommandManager.FindCommandBinding(System.Windows.Input.CommandBindingCollection, System.Object, System.Windows.RoutedEventArgs, System.Windows.Input.ICommand, Boolean)
at System.Windows.Input.CommandManager.FindCommandBinding(System.Object, System.Windows.RoutedEventArgs, System.Windows.Input.ICommand, Boolean)
at System.Windows.Input.CommandManager.OnCanExecute(System.Object, System.Windows.Input.CanExecuteRoutedEventArgs)
at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean)
at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs)
at System.Windows.Input.RoutedCommand.CanExecuteImpl(System.Object, System.Windows.IInputElement, Boolean, Boolean ByRef)
at System.Windows.Input.CommandManager.TransferEvent(System.Windows.IInputElement, System.Windows.Input.CanExecuteRoutedEventArgs)
at MS.Internal.Commands.CommandHelpers.CanExecuteCommandSource(System.Windows.Input.ICommandSource)
at System.Windows.Controls.Primitives.ButtonBase.UpdateCanExecute()
at System.Windows.WeakEventManager+ListenerList.DeliverEvent(Listener ByRef, System.Object, System.EventArgs, System.Type)
at System.Windows.WeakEventManager+ListenerList.DeliverEvent(System.Object, System.EventArgs, System.Type)
at System.Windows.WeakEventManager.DeliverEvent(System.Object, System.EventArgs)
at System.Windows.Input.CommandManager.RaiseRequerySuggested(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at Autodesk.ProcessPower.PnP3dSpecAndCatalogEditorUI.App.Main()
Source: Application Error
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: -
Description:
Faulting application name: SpecsAndCatalogsEditor.exe, version: 10.100.46.1003, time stamp: 0x5b7f61ac
Faulting module name: KERNELBASE.dll, version: 10.0.19041.662, time stamp: 0xec58f015
Exception code: 0xe0434352
Fault offset: 0x000000000002d759
Faulting process id: 0x480
Faulting application start time: 0x01d6e99d455cca25
Faulting application path: C:\Program Files\Autodesk\AutoCAD 2019\PLNT3D\SpecsAndCatalogsEditor.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: eef34313-b34c-4dcc-bac1-2753f46b069e
Faulting package full name:
Faulting package-relative application ID:
I have to keep my job all the time. But it happens every 5-10 minutes.
Tested on versions 2019/2020. This happens much more often on the 2020 version.
