Flange Group Annotation trouble
jperez46LZW
jperez46LZW
I am trying to separate the Flange and Gasket Bubbles.  We do not list Bolts in our BOM where I work.  I created a Flange/Gasket group and if I enable the multiple blocks option I get no bubbles on the Iso.  For the moment it seems I am stuck with one bubble with Flange and Gasket numbers together.  Any help will be appreciated.  using Plant 3D 2023.
Here is my XML for the Group Scheme.
Jon
JON PEREZ
Flowco
Drafting Coordinator
Natural Gas Technologies
Replies (8)
AndyDavisArkance
Hi Jon,
I've been looking at this and it seems that the group schemes expect to have 3 components and pass 3 ids through to an annotation block.
For a workaround, I have managed to persuade it to display just flange and gasket ids with a new annotation block that receives all 3 ids as attributes but only displays 2.  I also swapped around the bolt and gasket Tags in the GroupFormat:
In the block editor, attribute X06 is set to invisible, the rectangle is a wipeout frame:
I hope you find this useful.
Andy
Andy Davis
Industry Specialist
ARKANCE
jperez46LZW
Thanks Andy.  I'll try to implement this and will get back to you.  What are you using to edit and view the XML?  I have been using XML notepad, and I admit I am not crazy about it.
I still have concerns, because there are no bolts in our models.  It is considered a stock item for the shop, and we don't include them in our designs.  So I am wondering if this is going to cause more issues
JON PEREZ
Flowco
AndyDavisArkance
I use firstobject XML editor - its the best I've found.
Andy
Andy Davis
Industry Specialist
ARKANCE
jperez46LZW
Me again.  I have been busy today and still haven't been able to try and implement this.  Andy, you made a custom block using one of the provided blocks I'm assuming?
JON PEREZ
Flowco
jperez46LZW
Andy.  It took some finesse in the IsoConfig, but I got it working without having to create a new block.  Thanks for your guidance with this.  You've been a big help!  I do have one more question though.  In your picture the leader is pointing at the lead bubble, mine is pointing to the center between the two.  How can I change that without manual manipulation?  Sorry for asking about the simple stuff, but I am just getting my feet wet in the advanced settings and IsoConfig.
At First it wouldn't work, then I set IncludeMate to "false" and it worked.
Thanks Again!
Jon
JON PEREZ
Flowco
h_eger
Unfortunately, as far as I know, the arrangement of the guide line is not adjustable. This always goes to the geometric centre point.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
AndyDavisArkance
Hi Jon,
Pleased you have this working now, and thank you for the input.
I was not able to get this to work simply by setting IncludeMate to false.
Comparing my isoconfig with yours, I have noticed that the lines GroupFormat Count="3" and GroupFormat Count="4" also need to be removed to make it work.
The position of the leaders is controlled by the AnnotationLeaderStyle setting LeaderConnectionPoint. 3 options: AnnotationMiddle, AnnotationCenter and AnnotationCorner give the following results:
AndyDavisArkance_0-1741941822024.png   AnnotationMiddle
AndyDavisArkance_1-1741941860196.png   AnnotationCenter
AndyDavisArkance_2-1741941923212.png   AnnotationCorner
Andy
Andy Davis
Industry Specialist
ARKANCE
jperez46LZW
"Comparing my isoconfig with yours, I have noticed that the lines GroupFormat Count="3" and GroupFormat Count="4" also need to be removed to make it work."
You are correct.  Sorry I didn't mention taking those out.  It was late and my Brain was close to clocking out for the day.
JON PEREZ
Flowco
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
